-22b front wide fenders
-22b front bumper
-jdm aluminum hood
-chargespeed carbon reverse scoop
-jdm oem side skirts
-v6 jdm rear bumper and spats
-jdm v6 rear wing on white trunk
-apr-200 carbon wing on digi camo wrapped trunk
-oem sunroof (works)
-v6 front grill
-black housing clear headlights
-beatrush undersplitter front panel
Car was completely painted at freskies custom with glass shield paint and clear (super tought)
body interior
-AGMS 6pt custom welded in cage with precision door bars (dont intrude on leg space)
-V7 sti seats on stock seat rails (lower seat)
-v6 sti 8krpm cluster
-Defi link STI GENOME boost gauge
-Lamco oem gauge pod (boost,volts,oil temp) boost and volts not hooked up redundant due to vipec
-beatrush rear seat delete firewall
-lachute performance shift knob
-sparco prodrive steeringwheel
-nrg quick release
-stock 02 wrx radio (cd player doesnt work)
-oem sub
-ntk wideband custom mounted in drivers vent
-optima red top relocated to trunk
Engine 413whp 360wtq
-jdm v7 block
-jdm v7 crank
-carillo A beam rods (1000hp)
-manley forged pistons
-acl race bearings
-arp head studs
-oem sti head gaskets
-v7 sti heads fully ported by John at attelier performance powerflow
-stainless intake valves, inconel exhaust valves
-manley springs and retainers
-all cam sensors replaced
-new ntk tensioner
-gates racing timing belt
-pulleys replaced
-tgv port matched to head and hollowed out
-v7 sti intake
-agency power fuel rails
-deatchwerks 1000cc injectors
-agtronic motorsports custom 600hp garrett intercooler and piping.
-tial gold anodized bov
-aquamist meth injection system
-walbro 255lph (intank replacement)
-mitsubishi TD06-20g 8cm hot side stock location (rebuilt a year ago)
-gt spec v1 equal length header
-new grimspeed 38mm ewg up pipe
-tial 38mm vband wastegate
-agtronic motorsport custom full 3.5" turbo back with vibrant resonator and VAREX variable muffler
-turbo oil feed line and avcs solenoid line replaced with braided lines (more flow)
-huge aem dryflow air filter
-aps big inlet pipe
-2006+ sti oil pan
-killer b oil pickup
engine management
-Vipec plug and play ecu (full motorsports features, als, lc)
-oil pressure sensor
-fuel pressure sensor
-oil temp sensor
-gm 3bar map
-grimmspeed ebcs
-vipec iat (rapid response)
--- tuned by sebastien guay at precision efi on 94oct
Cooling system
-mocal big oil cooler with pushlock lines and thermostatic oil sandwich plate.
-koyo aluminum rad with custom agtronic motorsport shroud
-2 x flexalite 12" fans
-sti power steering cooler
drive train
-Exedy twin disc clutch with HD pressure plate (1 year old)
-sti s202 6speed trans with viscous center diff (new) and apsuretrack front diff
-R180 rear diff suretrack (low km)
-stock sti shift linkage with urethane bushings throughout
brakes
-sti brembos front and back
-dba 4000 fonrt rotors (new)
-brembo blanks rear rortors
-stoptech sport pads (new)
-single stage brake booster
-svx big mastercylinder
-goodridge lines
-NO ABS (pump still in system(
-Motul rbf660 fluid
Suspension
-bc racing coilover set with bc top plates
-perrin rear 26mm swaybar with aluminum perrin links
-syms rear strut bar
wheels tires
-rota tarmac 3 17x8 et48
-dunlop direzza z1 star spec 235/40/17 (60-70percent tread)
PRICE: 27,500$ not in a hurry to sell, reason for sale house/bought a bike.
Uploaded with ImageShack.us
